Hi guys,
I have been searching for an answer to this one for over a week now and am doing my head it!
Basically I just want to be able to set up a AP/WDS using an Ubiquity SR9 radio in a RB133 and connect to it using a PC with a MiniPCI slot running Windows XP.
Seems easy right?
Well, no…
Does anyone have a basic config that allows this? Using the Ubiquity Mobility Driver and Utility on XP, sometimes I can see the RB and even get a connection but am unable to ping or pass data.
Does the country code settings in the RB have anything at all to do with this? I can’t seem to set Australia, because WinBox complains about an incorrect channel (Zimbabwe works though
I have asked the Ubiquity guys at: http://ubnt.com/forum/viewtopic.php?p=36544#36544
Also have a private response back from Ubiquity that says it must be something wrong with my RB config. (Can connect to it with another RB though).
Best regards,
James
