SR9 resetting
I have 5 locations running SR9’s.
The problem I have is at 1 location only, there are 7 client side SR9’s running.
I’m getting random re-connects on all the units, sometimes they all stay up for 2 days and then ALL of them re-connect within a minute of each other.
Other times half of them disconnect/re-connect and the others stay up. when they disconnect they re-connect within MS.
Have tried battery backups on some of the locations, no go !
running -70 to -75 on all units.
There is a Canopy link from someone else around this location, is there a way to filter for this ?, the Canopy is running 5.8.
[/img]
Same problem here so dont feel alone, I think there is a driver problem with MT. Signals are good here as well runnin N-Streme. Customers dont complain, its like a hiccup. Anyone else???
Interference?
Check the noise floor when the clients drop, I bet it will be worse than normal.
-Gerard
Could you please be more spesific on your configuration. How many SR9’s have you got in one RB? What kind of power supply are you using? (I want the voltage and amperage)
My first thoughts are not enough current to power all the cards, perhaps your usage is a lot higher at the time of the disconnects.
