Src.address getting ignored netwatch
Trying to set up Netwatch for my LTE failover. It pings 1.1.1.1 and switches to LTE when the main connection fails. However, it continues to ping 1.1.1.1 through the LTE connection and mistakenly reports that the main route is fine, causing it to switch back to the main connection, which then fails to ping again. This results in an endless loop of switching between LTE and the main connection. I’ve set the Src. address in Netwatch to the IP of the main ISP, but it seems to ignore that setting. Below are my configuration and logs.
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band=“” sms-read=no
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=pool1 ranges=192.168.xx.xx-192.168.xx.xx
add address-pool=pool1 interface=bridge name=defconf
/port
set 0 name=serial0
add comment=defconf interface=lte1 list=WAN
add interface=ether1 list=WAN
add address=103.95.xx.xx comment=WAN1 interface=ether1 network=103.95.xx.xx
add address=192.168.xx.xx/24 interface=bridge network=192.168.xx.xx
add address=192.168.xx.xx/24 dns-server=192.168.xx.xx gateway=192.168.xx.xx netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.xx.xx comment=defconf name=router.lan
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=WAN
add check-gateway=none comment=MAINROUTE disabled=no distance=1 dst-address=0.0.0.0/0 gateway=103.95.xx.xx pref-src=“” routing-table=main scope=30
suppress-hw-offload=no target-scope=10
/system clock
set time-zone-name=Australia/Brisbane
/system identity
set name=“4g backup”
/system logging
add topics=debug
/system note
set show-at-login=no
/tool netwatch
add disabled=no down-script=“/ip route disable [find comment="MAINROUTE"]\r
\n:log error "ISP1 is down"” host=1.1.1.1 http-codes=“” interval=7s src-address=103.95.xx.xx startup-delay=0s test-script=“” timeout=1s type=icmp
up-script=“/ip route enable [find comment="MAINROUTE"]\r
\n:log warning "ISP1 is up"”
/tool sniffer
set filter-interface=lte1
I also see that src-address is ignored. I have a Chateau LTE6 AX and I am using an LTE connection as a backup for a FTTP connection. Testing the FTTP connection with
/tool/ping 1.1.1.1 interface=pppoe-out1
gives ping times < 5ms.
Using
/tool/ping 1.1.1.1 interface=lte1
gives ping times > 50ms. So /tool/ping is using the expected interface and the significant difference in times can be used as a check for netwatch.
When I set the src-address in /tool/netwatch to the lte1 IP address the status response times I get for type=simple, icmp, or tcp-conn are all much less than 50ms, the connections cannot have used LTE. When I test with type=http-get or https-get with a server I own I can see from the access.log file that the connections came from the pppoe-out1 IP address.
My workaround is this
add comment="Force 4.2.2.1 to use FTTP network (for Netwatch)" disabled=no distance=1 dst-address=4.2.2.1/32 gateway=pppoe-out1 \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add comment="Force 4.2.2.2 to use LTE network (for Netwatch)" disabled=no distance=1 dst-address=4.2.2.2/32 gateway=lte1 routing-table=main \
The 4.2.2.x Level 3 servers are only used by netwatch so adding special routes hasn’t caused a problem so far.
Did you report the problem to Mikrotik?
Same here, using the local IP address of the WG peer in Netwach as an src-address doesn’t pass the traffic through the WG tunnel, instead, it goes out from the main interface.
The OP, original poster shows no route information at all, either from the config or snapshot of actual winbox ip route setup, so not enough info.
Simply change 1.1.1.1 to your public ip of ether1. And use 30 sec interval
As the OP didn’t reply to say it had been reported to Mikrotik I have now reported it (SUP-158089).
