Src. Address List - does not working
Hi All,
After upgrade CRS238-24p to 6.48.3 my firewall rules using Src. Address List does not work any more.
Is anybody on forum experiencing this kind of issue ?
I was afraid I skipped so many versions.
it is 6.43.8.
No problems with source lists
  1. what was previous ROS version where it worked?
  2. what is your current ROS version? (as pointed by @inteq, 6.48.3 does not exist and it will probably be 6.43.8. just making sure)
  3. ****what specific rule are you using? is it
/interface bridge filter
or
? (or any other?) Ideally just share whole
/export hide-sensitive
.. It should be pretty clear where is the trouble. If you are worried about personal data, feel free to find+replace all occurences with some meaningful string.
My first guess would be some BC-break feature, typically hw-offloading which was not originally active, but now it is active and it prevents CPU to see bridged packets, therefore firwall ruless are completely avoided.
All sorted out - connection was from different VPN tunnel with IP not listed on address list.
