Hi all,
I can figure out how to use this darn SRC or DST address thing, if i have a port setup to forward to a specific IP can i limit it to 2 IP address only? And would it be under SRC or DST address under NAT or Mangle…or both?
Actually is this doable or have i missed the plot?
Setup is as follows
RB750-1 - IP 192.168.88.200 (eth1)
IP 192.168.1.2 (eth5)
PF on port 5900 to go to 192.168.1.5 from ether1 to ether5 (eth5 connects to a switch which is connected to RB750-2)
PC 192.168.1.5
RB750-2 - IP 192.168.1.1 (eth1)
PF setup for VNC to go out via one of two adsl modems (eth2) using PCC
I have tried forwarding to both devices, Im sure this is simple, Do i pf to the RB750-2 or the PC itself, and once its there do i mark it with different routing mark and route it back to the RB750-1? If my thinking is right…where should i start?
I couldnt get any traffic to pass with the IP specified, but it would start when i set it to the ethernet port, is this a routing issue maybe? Basicially i want to make this darn PC accessible from ether1 and im on ether5. The two networks are separate but i can ping everything from RB and the RB from each PC.
I even tried sending the traffic to the 2nd networks Routerboard then NAT’d and mangled it with a route back to the IP it came from. I saw the packets even starting to go on the second routerboard but it wont come back to me, lol
