Src port 1024
There’s a weird problema with lastest version of routersOS 6.19-6.22.
Devices who start theyre connections with source port starting from low range ports (1024->) don’t work at first time when port 1024 is used, they only start working when a second connection is made and the port 1025 or higher is used, even with conenction tracking disable on the router that makes de pppoe server role.
Anyone have got the same problem?
