I have an RB4011, 2 WAN connections and one private subnet which gets NATed for internet access.
WAN1 has a /27 range alocated from ISP, while the secondary WAN2 is mainly for backup, just one IP.
WAN1 uses srcnat ‘one-to-one’ NAT:
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.100 to-addresses=188.110.255.100
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.101 to-addresses=188.110.255.101
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.102 to-addresses=188.110.255.102
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.103 to-addresses=188.110.255.103
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.104 to-addresses=188.110.255.104
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.105 to-addresses=188.110.255.105
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.106 to-addresses=188.110.255.106
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.107 to-addresses=188.110.255.107
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.108 to-addresses=188.110.255.108
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.109 to-addresses=188.110.255.109
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.110 to-addresses=188.110.255.110
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.111 to-addresses=188.110.255.111
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.112 to-addresses=188.110.255.112
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.113 to-addresses=188.110.255.113
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.114 to-addresses=188.110.255.114
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.115 to-addresses=188.110.255.115
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.116 to-addresses=188.110.255.116
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.117 to-addresses=188.110.255.117
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.118 to-addresses=188.110.255.118
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.119 to-addresses=188.110.255.119
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.120 to-addresses=188.110.255.120
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.121 to-addresses=188.110.255.121
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.122 to-addresses=188.110.255.122
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.123 to-addresses=188.110.255.123
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.124 to-addresses=188.110.255.124
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.125 to-addresses=188.110.255.125
add action=src-nat chain=srcnat comment="NAT" src-address=192.168.1.126 to-addresses=188.110.255.126
This works perfectly.
When I want to swap to WAN2 I do the following:
- Disable above rules
- Enable either src-nat masquerade:
add action=masquerade chain=srcnat comment="backup-NAT" out-interface=ether8 src-address=192.168.1.0/24
or src-nat:
add action=src-nat chain=srcnat comment="backup-NAT" src-address=192.168.1.0/24 to-addresses=86.123.188.201
How can I create a working automated swap from WAN1 to WAN2 and viceversa when one of the WAN connections fail on me?
Are there any mangling rules which can be applied or should I use scripting engine?
