You have four IP pools aka four vlans but you have identified 10 vlans??
Yes, I have 4 pools for the 4 vlans with a dhcp server. In the other vlans ip addresses are managed manually.
IP filter strict is not usual…loose is the preferred setup.
I tried to make it as secure as possible nowadays. I changed it now to “loose”, but this did not solve my problem.
I am still debugging and trying to find the problem. I am a little unsure if the routing rule really works as expected.
As you know I configured it as recommended:
- a route with destination 0.0.0.0/0, gateway=192.168.71.244 (opnsense-lan) and routing mark=useOP
- a routing rule with src-address=192.168.2.0/24, action=“lookup only in table” and table=useOP
To me it seems, as if the packets are looping: 192.168.2.21 tries to send a dns request to 8.8.8.8:53 results in:
192.168.2.21 → 192.168.2.254 (RB4011) → routing to 192.168.71.244 → 192.168.72.254 (RB4011) → routing to 192.168.71.244 → and so on
How shall the traffic “break out” to the internet after looping once above opensense?
