One of my routerboards (the gateway of my network) are trying to access the others network ips via ssh and telnet. The log them is showing several trials and logins errors like brute force. A virus maybe?
Thanks in advance and sorry for bad english.
can you show the logfile please?
DHCP-alert for detect roque DHCP-servers?
Are you sure that router is the originator of the attack? Or some computer behind it?
The router isnt the originator of the attack,.I’m sure about this, however the ip (public ip) is a source of attack.
add a new firewall rule
Like this on the printscreens a made.
You can read the ip-address in “address lists” who try login and block these for 10 days
The first picture is the result, you can read the IP-address from the attacker
Ty for help me .The last ask , its possible someone use the same ip (public ip) of my routerboard and this is dangerous?
You can configure a rogue DHCP-server alarm on your DHCP-server
Tis for see if somebody else turn a DHCP-server on your network.
See on my website how to do this
http://www.wirelessinfo.be/index.php/mikrotik/pages/dhcp-alerte
IF you have set the roque DHCP-server alarm a email will sent to you.
In firewall address list you see the IP-address that try login.
It’s danger because he can take over your network.
This can you help you too.
http://www.wirelessinfo.be/index.php/mikrotik/pages/services
Sorry this webpages is in dutch but follow the printscreens a made.
By carefull that you put in the IP-address from your PC
Only you can than login into your routerboard
I have set a printscreen by the other two by firewall rule
This is the result that you can see.
Thanks for add the karma a appreciate that.
