SSH CLI Failed
Good morning to all, since some versions, I can not save the changes in the rules via ssh. the control + O, does not work correctly. I connect from the mobile using the Terminus app. some idea to solve the problem
Enviado desde mi iPhone utilizando Tapatalk Pro
Use set instead of edit when making changes to commands if you are having issues with your emulator. There are times I have to use my mobile to assist clients, and I use JuiceSSH
