Hi Guy’s
I have a strange problem and I think it’s because of the MT Loadbalance.
This is my DNAT rule which seems to be working fine.
chain=dstnat dst-address=172.22.2.100 protocol=tcp dst-port=22 action=dst-nat to-addresses=192.168.1.68 to-ports=22
I can see the connection coming into the MT but at the remote end it is just timing out. I think this is due to the request coming in one WAN connection and returning on the other WAN connection. Can anyone tell me how I can make sure that the port 22 request routes back out the same connection it came in on.
Thanks Mark
you have to mangle those packets coming in WAN2 and send them back out wan2. Search this thread for an example:
http://forum.mikrotik.com/t/policy-routing-logging-in-problem/14153/2
Sam
Hi Sam,
Thanks for the pointer. I still can get this dam thing to work. I ran touch and can see that dst-nat is working but I am still not getting a response back from the server. I have tried to mark the connection, packet and route and added the static+policy please see below:
x.x.x.x = the client address trying to connect to the server. I am not 100% sure it should be that address.
27 chain=prerouting dst-address=x.x.x.x protocol=tcp dst-port=22 connection-mark=ssh action=mark-connection new-connection-mark=ssh passthrough=yes
28 chain=prerouting dst-address=x.x.x.x protocol=tcp dst-port=22 packet-mark=ssh action=mark-packet new-packet-mark=ssh passthrough=yes
29 chain=postrouting dst-address=x.x.x.x protocol=tcp dst-port=22 routing-mark=ssh action=mark-routing new-routing-mark=ssh passthrough=yes
2 dst-address=86.22.69.205/32 action=lookup table=ssh
Bascially I need to make sure that the ssh return path is routed out through WAN1 …
Thanks Mark
rather than trying to only route ssh out wan2, you should route anything that comes in WAN2 back out wan2.
27 chain=prerouting in-interface=wan2 action=mark-connection new-connection-mark=in-wan2-conn passthrough=yes
then mark those packets belonging to in-wan2-conn with a new packet mark, and then route mark those packets. in-interface=wan2 is the key, you want to mangle anything coming in wan2 so you can later send it back out wan2. There is a clear example of this on the link above.
Sam
Hi Sam,
I used you example and mangle picked up the traffic. I then added the routing policy. I then noticed that ether1 had not TX rate … it was receiving but no TX … I disable the policy and the TX started working again ???
Strange
Mark
go ahead and post the following if yo uwant me to look at it more:
/ip route export
/ip firewall mangle export
Sam
this is a variant of the problem i’ve been strugglign with – read a few of my posts for some solutions…
