SSH connection reset by peer to all 5.x, not 4.x
I have some odd issues with some Routerboards. SSHing to them from a host disconnects after authenticating as follows:
> ssh username@10.170.1.15
username@10.170.1.15's password:
Read from remote host 10.170.1.15: Connection reset by peer
Connection to 10.170.1.15 closed.
But the same username/password work from another host on the same source subnet. I’ve verified that any input rules that block or drop don’t exist. The system is FreeBSD 7.4-p2, SSH version is OpenSSH_5.1p1. This appears to happen when I connect to ANY RouterOS v5.x, all connections to v4.x and to any other non-mikrotik product such as Cisco routers/switches, Juniper, Linux and FreeBSD hosts works fine.
Debug logs on the Mikrotik show below (Also I have a txt file with more debug info (packets) right here if that’s important):
15:29:15 ssh,debug auth req: falz ssh-connection password
15:29:15 ssh,debug getting user password for: falz
15:29:15 ssh,debug user falz authorized fffe 0
15:29:15 ssh,debug transport state: 2 --> 3
15:29:15 ssh,debug opening channel 0:0 100000,4000
15:29:15 ssh,debug global request: no-more-sessions@openssh.com
15:29:15 ssh,debug unimplemented: 80 in 4000200
15:29:15 ssh,debug => offset:38 [0x26]
15:29:15 ssh,debug => size:27 [0x27]
15:29:15 ssh,debug 0000 002c 0950 0000 001c 6e6f 2d6d 6f72
15:29:15 ssh,debug 652d 7365 7373 696f 6e73 406f 7065 6e73
15:29:15 ssh,debug 7368 2e63 6f6d 00
15:29:15 ssh,debug closing connection: <broken connection> ::ffff:10.170.1.15:60956 (11)
15:29:15 ssh,debug channel exit code: 0
And verbose from the ssh client:
> ssh -v 10.170.1.15
OpenSSH_5.1p1 FreeBSD-20080901, OpenSSL 0.9.8q 2 Dec 2010
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Connecting to 10.170.1.15 [66.170.0.205] port 22.
debug1: Connection established.
debug1: identity file /home/falz/.ssh/identity type -1
debug1: identity file /home/falz/.ssh/id_rsa type -1
debug1: identity file /home/falz/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version ROSSSH
debug1: no match: ROSSSH
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.1p1 FreeBSD-20080901
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Host '10.170.1.15' is known and matches the DSA host key.
debug1: Found key in /home/falz/.ssh/known_hosts:157
debug1: ssh_dss_verify: signature correct
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Trying private key: /home/falz/.ssh/identity
debug1: Trying private key: /home/falz/.ssh/id_rsa
debug1: Trying private key: /home/falz/.ssh/id_dsa
debug1: Next authentication method: password
falz@10.170.1.15's password:
debug1: Authentication succeeded (password).
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: Received SSH2_MSG_UNIMPLEMENTED for 8
debug1: channel 0: free: client-session, nchannels 1
Connection to 10.170.1.15 closed by remote host.
Transferred: sent 1632, received 1312 bytes, in 0.0 seconds
Bytes per second: sent 125191.7, received 100644.3
debug1: Exit status -1
Both sides show an ‘’‘unimplimented’‘’ error message so this appears to be the issue.
I can connect to the Routerboard via telnet from this host with no problem, it’s something specific with SSH.
Analyzing with a packet dump shows the mikrotik (0.205 in the screenshot) sending RST- the first distorted column is source IP, second is destination:
I do use RADIUS auth on the devices but the behavior is the same with a local user as well. I’ve had this behavior on RB1100 as well as the above devices which is an RB/SXT running 5.6. The RB1100 that had this issue was running 5.4 or 5.5.
This happens when coming from any user on that host so it’s not some issue with a known_hosts file or similar. This machine is where my RANCID install lives so unfortunately it’s unable to get configs from a few devcies.
Thoughts or ideas?
Edit: Just found this thread with the same issue, same OpenSSH version of OpenSSH_5.1p1.
found the fix. It’s a combination of what OpenSSH considers a ‘broken implimentation’ of SSH by Mikrotik (as well as other vendors such as Juniper) and OpenSSH 5.1.
The Changelog shows: http://www.openssh.org/txt/release-5.2
* Due to interoperability problems with certain
   broken SSH implementations, the eow@openssh.com and
   no-more-sessions@openssh.com protocol extensions are now only sent
   to peers that identify themselves as OpenSSH.
And here’s the commit:
I compiled a different version of OpenSSH and it connects fine with their workaround. RouterOS’s changelog for 5.x says that its SSH daemon is a complete rewrite. Mikrotik, unsure how much you care about this bug but it appears that at least some people have encountered it, if it’s an easy fix I’d recommend doing so, it may save people some time.
with RouterOS 5.7 you will not have to patch your client. :wink:
Excellent! I don’t have a way to test this currently but thanks for the fix.
i am using 5.17 and having same problem !
