montie
September 11, 2016, 12:09pm
1
Hello, I have the same problem, as in topic http://forum.mikrotik.com/t/ssh-port-forward/72800/1 It also returns me “connection refused” message. But the code
add chain=dstnat action=dst-nat in-interface=ether1-gateway protocol=tcp dst-port=2022 to-addresses=[myDestIP] to-ports=22
add chain=forward in-interface=ether1-gateway protocol=tcp dst-address=[myDestIP] dst-port=22
doesn’t seem to change the situation. Please help.
Sob
September 11, 2016, 12:36pm
2
Where do you test it from? When it has in-interface=ether1-gateway, it will only work from outside, not from same LAN.
I’m having a similar issue, so what would be the correct way to set it up, in order for it to work from outside as well from the inside, to create the same rule for the LAN?
Many thanks!
Sob
September 11, 2016, 6:01pm
4
There’s very nice and detailed article about making it working from inside.
montie
September 11, 2016, 6:21pm
5
Thanks a lot, that was the problem. And for the article too!
Thanks for the article.
I have to add that the following post, also helped a lot: http://forum.mikrotik.com/t/solved-hairpin-nat-not-working/97689/1
