Sorry for interfering, but the name and explanation of that item in the manual is so unclear that myself I wouldn’t dare to refer to it without an additional explanation.
What are the conditions which must be met so that the password authentication would be disabled? Once you import a key for a given user, it means that that very user cannot log in using a password authentication any more if the always-allow-password-login is set to no? Or as soon as you import a key for a single user, password authentication is disabled for everbody? Or it works like in linux sshd and it only affects root (i.e. admin here)? I mean, there is so much space for speculation that I would be afraid to try, assuming I might ban myself from access to the router via ssh.
“/ip ssh set always-allow-password-login=”
NO => when “user” have added public key, then you cannot log in with the password for a specific user, only cert (password prompt is still showing, but not accept password)
YES => you can connect to user account with password or certificate
Nice to now. It has annoyed me that I need to login with a cert.
Looked everywhere in the GUI, but could not find anything.
Then the always-allow-password-login solved it.
Strange that /Ip SSH is missing for webgui/winbox
