I have an EoIP tunnel overlaid on an L2TP/ipsec VPN. The L2TP/ipsec VPN connects from a hEX to an RB3011. The hEX is NAT’d behind an ADSL modem operating in PPPoE mode. The RB3011 has a static public IP address. The hEX is connecting to the L2TP server on the RB3011. The EoIP tunnel is then negotiated across the L2TP VPN. The EoIP tunnel is added to a bridge on both ends. The L2TP interface is not part of a bridge on either end.
The RB3011 has an additional SSTP VPN used for external management.
The RB3011 is at 10.10.30.1. The hEX is at 10.10.30.32.
There is a FreeNAS device at 10.10.30.254 which is on the same physical network as the RB3011.
There is a second FreeNAS device at 10.10.30.253 which is on the same physical network as the hEX.
The SSTP VPN is at 192.168.100.2.
The L2TP/ipsec VPN has a 192.168.105.1 on the RB3011 and 192.168.105.2 on the hEX.
SSH from a Ubuntu 20.04 box at 192.168.100.1 can log in on SSH to both FreeNAS boxes.
10.10.30.253 can successfully SSH into 10.10.30.254 and 10.10.30.32 and 10.10.30.1
10.10.30.254 can successfully SSH into 10.10.30.1
10.10.30.254 can connect to port 22 on both 10.10.30.32 and 10.10.30.253, but the connection stalls before it gets to the login prompt. The connection stalls at different progress points on each of these devices.
When connecting to 10.10.30.32, it gets to:
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(2048<7680<8192) sent
After about a minute or two, it’ll get connection timeout
When connecting to 10.10.30.253, it gets to:
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
After about a minute or two, it too will get a connection timeout
I’ve checked firewall and bridge settings. The firewall settings are non-existent on the hEX side. The firewall settings are still pretty stripped down and nothing out of the ordinary on the RB3011 side.
The biggest differences I can see between the two sides are that the RB3011 side has root bridge unchecked for the bridge, and the hEX side has root bridge checked for the bridge. Also, on the RB3011 side, the EoIP tunnel has root port status, and on the hEX, it does not.
Anyone have any ideas as to why the traffic is 100% successful in one direction and in the other direction, it stalls during protocol negotiation? Any ideas on how I might troubleshoot the root cause?
