SSH not working behind mikrotik
I have Mikrotik RB952Ui-5ac2nD. Everything is working fine.
But now, I found little problem.
I can not connect from LAN to any SSH in internet, but, when I’m connected without mikrotik, i havent any problem.
If I’m conecting to SSH in internet from mikrotik terminal, I will connect without probelms. But If I want connect from pc behind mikrotik I haven’t got any response-
I have configured only nat masquarade in firewall.
Do you know, what I need to solve that, please?
Thank you
Open multiple time same topic do not help,
instead to spend time to post it multiple time, better is spend that time with specify at least RouterOS used, network diagram and current config.
or do you think we have glass balls here?
Try RouterOS console command: /ip firewall export
Examine “chain=forward” lines.
I thought yours were petrified :wink:
