I want to try to create a reverse SSH tunnel so I can manage my router thats behind a NAT address via SSH, my remote box I want to use is running on a non standard port and looking at the wiki there is no reference to port numbers ?
I’m a little confused about what you are trying to do, so let me make sure I have it right. You have a RouterOS based router that you want to control via SSH on a non-standard port. That router is behind some other router that is doing NAT. Do I have that right? If that’s the case, that’s easy.
In your RouterOS device, in IP services, set the port for SSH to whatever port you want (for the purposes of this example, set it to port 9876). Depending on your firewall settings, you may need to explicitly allow that port in the Input chain.
In whatever device is doing the NAT, you will need to set up a port forwarding for port 9876 to the IP of the RouterOS device.
If I did not understand what you are trying to do, give a bit more detail on what you are trying to do.
I have a 4G router (SXT LTE) that is connect to a UK provider that only issue CGNAT IP’s, so I cannot connect directly to any DNS name or IP for the router.
My thinking was to SSH out from the router to a Linux box I have with a fixed IP to establish and SSH tunnel that I could then use top manage the router remotely. The remote Linux box is on an non standard SSH port.
Open to alternative ways to achieve this but this is the easiest way I can think of (if its possible).
