Hi all,
I have this problem
when i execute this in mikrotik routeros console, it shows me 3 times text
:put text ; :put text ; { :put text ; :put text;}
text
text
text
text
but when i do it via ssh, it interupt on semicolon inside braces:
ssh user@mikrotikmachine ’ :put text ; :put text ; { :put text ; :put text;} ’
text
text
missing closing brace (line 1 column 14)
text
Does anybody know solution?
Using ; didnt help.
thx
now = in next release of ros?
Its possible to somehow patch my devices with ros from 3.3 - 4.17?
Because I cannot upgrade them to newest 5.x - I did it with 2 of tehm and my whole network have colapsed. After upgrading with 5.2 one of them generate 1000pps (without traffic) and halt lot of devices in network. After downgrade it was ok. I have about 50 of RBs in network.
There must some problem with configuration. We are running 5.x version in our network and have not seen such issues.
Things you can try - take router that had issues and get the configuration, upgrade to 5.x (5.3 is currently in testing), if you see problems, do reset0configuration and see if router still has problems, if not, recreate configuration from export you made earlier. It is after all, upgrade of major versions.
Its in runing network, I cant try it now. But when it happend i collect some data for debuging. I have export, suppout and backup files. I also have 10MB traffic dump from this device and devices in nearby. If someone want look at it.
