I have problem with logging to my RB133 via ssh on public IP.
Whenever I try to log-in via private IP, it works fine,
but whenever I try to log-in from remote, I get the same two errors:
“Network error: Connection Refused”
or
“Network Error: Time out”
I have no entries in /ip firewall filter section
I changed the ssh port at random, default also does not work.
My ISP configuration:
Cable Modem ==> RB133
Maybe it is caused by some restriction set by my ISP?
Check
If you have even the minimum defensive rules in there, then you probably need to allow your remote box in.
EDIT: I see by your post (duh!, I feel dumb) you have no rules in there. I will presume it may be your ISP blocking it. Can you ping it?
Also check /ip route and insure you have a default gateway to the internet there.
Sure I do have no defensive rules,
previously I had plenty of them,
but I dunno had a chance to check them against the validity of use.
I can not ping the public address of a router.
RB gets public address automatically, from the dhcp-client section and def-route and so on is added automatically.
That is what is suspected. 192.168.x.x is not a public IP set. That is a reserved private IP set. You will not be able to access those IPs directly from the internet.
EDIT: I won’t step on your next post. My bad. I thought that was a real IP. Then my first impression is probably correct. It is your ISP blocking it. Mine blocks port 80 (websites) unless you have a commercial account.
