SSL Cert Import Failure ROS 3.22
I have tried to install my SSL Cert on a x86 box running a fresh 3.22 netinstall. I used the same SSL cert that I have imported on previous versions of Router OS without problems but now no matter what order I import the cert and private key I get the same result QR for flags. and going to the https page returns nothing. I went back to a fresh install of 3.20 and the same cert and key import fine with KR flags and the https page works fine. Is there a possible bug ?
I have the same problem. My branding package also indicates that it is broken on 3.22.
Branding packages need to be re-made for use in new version! Log into your account to do it.
