Hello, when trying to create a SSL certificate as is on the manual
/certificate create-certificate-request
template:
Script Error: action cancelled
What should I set here? Error whatever I type. Thank you
template:
What version of RouterOS are you using?
http://forum.mikrotik.com/t/after-upgrade-to-6-3-cannot-generate-certificate-request/69304/9
Currently I’m using a older RouterOS version to create the CSR. Then have it signed. Then import into your v6 router board… Works just extra step for now.
Hello thank you for the reply. I am using v6.4. I searched but I did not found that answer about it.
