SSL Certificate problem (missing private key)
I’m trying to enable www-ssl, with a cacert signed certificate. I must be missing something.
My steps:
  1. /certificate create-certificate-request
    I fill all the details, specially common name and pass phrase. It generates 2 files, -private.pem and -request.pem
  2. I download the -request file, submit it to cacert, and obtain a signed certificate, which I upload by ftp
  3. /certificate import
    certificates-imported: 1
    files-imported: 1
/certificate print
Flags: K - decrypted-private-key, Q - private-key, R - rsa, D - dsa
 0    name="cert1" subject=CN=mydomain.com issuer=O=Root CA,OU=http:,,www.cacert.org,CN=CA Cert Signing Authority,emailAddress=support@cacert.org
      serial-number="0B9XXX" invalid-before=apr/10/2012 08:19:08 invalid-after=oct/07/2012 08:19:08 ca=yes
Notice there is not K, Q or R flags…
What am i doing wrong? Of course, I get ssl errors on every browser tested.. Here’s the output from openssl:
$ openssl s_client -connect mydomain.com:443
CONNECTED(00000003)
140019519768224:error:14094410:SSL routines:SSL3_READ_BYTES:sslv3 alert handshake failure:s3_pkt.c:1195:SSL alert number 40
140019519768224:error:1409E0E5:SSL routines:SSL3_WRITE_BYTES:ssl handshake failure:s3_pkt.c:591:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 7 bytes and written 0 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
SSL-Session:
    Protocol  : SSLv3
    Cipher    : 0000
    Session-ID:
    Session-ID-ctx:
    Master-Key:
    Key-Arg   : None
    PSK identity: None
    PSK identity hint: None
    Start Time: 1334048750
    Timeout   : 7200 (sec)
    Verify return code: 0 (ok)
> /system resource print
                   uptime: 1h4m16s
                  version: 5.14
              free-memory: 18816KiB
             total-memory: 29708KiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 680MHz
                 cpu-load: 3%
           free-hdd-space: 30980KiB
          total-hdd-space: 61440KiB
  write-sect-since-reboot: 1538
         write-sect-total: 3209
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB750G
                 platform: MikroTik
Thanks.
If you imported only the signed certificate from CA, import also the private key (private.pem). If it doesn’t work, it might have the wrong format, see the first note at http://wiki.mikrotik.com/wiki/Manual:Create_Certificates
I’m using CACert, which is free, but I could have used any commercial CA. The point is that I’m not using self-signed certificates, or custom CA.
The process I used is described here: http://wiki.mikrotik.com/wiki/SSL_Certificate_setup
Get the CA to sign the request, and upload the certificate.pem to the router
/certificate import file-name=certfile.pem
I assigned the certifiacate to the www-ssl services, but cannot connect with any browser. openssl s_client reports errors, as described in OP.
please check what is exactly happening here:
i know that that is for self generated certificates, but essentially only difference is that you do not have to generate CA key/certificate, because that is provided for you already.
And you have to decrypt it using the key for it to be used as certificate for www-ssl service.
Ok… i’ll try to generate the certificate from my computer, instead of using the router, which seems broken.
I’ll let you know.
Thanks!
I used this tutorial for generating the ssl cert: http://wiki.cacert.org/HELP/4
I faced the same problem.. The crt was imported but the key didn’t. Then I used the command mentioned in http://wiki.mikrotik.com/wiki/Manual:Create_Certificates
openssl rsa -in server.key -text > server2.key
It was then imported correctly.
Being curious, i tried the same command with the private-key.pem that the router’s create-certificate-request generates, and it actually worked.
I would consider it a bug, as the router is not importing the private key file it generates.
Julian.
Funny, isn’t it? :wink: But as the note says, it should be fixed in next version.
Which next version? :confused:
