When I generate a CSR (using RB ROS v3.3) for GoDaddy, I can make up any FQDN for the Common Name?
For example http://www.hotspot1.mickeymouse.com -
Then I will submit CSR to GoDaddy, and follow howto’s to import my SSL certificate
When I setup the hotspot, I MUST enter the SAME FQDN for DNS Name?
Hotspot customers see https://www.hotspot1.mickeymouse.com/login.html?
Thanks! I am grateful for any help you can provide.
