I am trying to access RouterOS and then query the API.
I use the following to test the connection
It works without SSL, and I get OK
$host = "192.168.50.20";
$port = "8728";
$checkconn = fsockopen($host, $port, $errno, $errstr, 5);
if(!$checkconn){
echo "($errno) $errstr";
} else {
echo 'ok';
But with SSL, it does not work
$host = "ssl://192.168.50.20";
$port = "8729";
if(!$checkconn){
} else {
echo 'ok';
I get following errors:
Warning: fsockopen(): SSL operation failed with code 1. OpenSSL Error messages: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure in /srv/test.php on line 38
Warning: fsockopen(): Failed to enable crypto in /srv/test.php on line 38
Warning: fsockopen(): unable to connect to ssl://192.168.50.20:8729 (Unknown error) in /srv/test.php on line 38
I have /ip/services/print as following:
NAME PORT ADDRESS CERTIFICATE
0 X telnet 23
1 ftp 21
2 www 80
3 ssh 22
4 X www-ssl 443 none
5 api 8728
6 winbox 8291
7 api-ssl 8729 none
Any input is appreciated.
