SSL problem with user manager
I’ve moved user manager from an RB433AH to an x86 based system.
The move was seamless. I changed the IP address for the server in DNS, flushed DNS and users can access their control panel as usual.
BUT I’m having lots of problems getting my SSL certificate sorted.
So far:
I followed the instructions here and made a new certificate-requext.pem
http://wiki.mikrotik.com/wiki/SSL_Certificate_setup
I logged into godaddy.com, found the certificate for this site, asked for a re-key and entered the data from the .pem file. All went well and I downloaded the new certificate.
I uploaded the certificate to the machine and imported it.
Now it’s there.
I tried to decrypt it. Nothing. No matter what password I enter, I can’t decrypt it.
I’ve got rhe www-ssl service running with the certificate, but all I get when I try to go to the secure site is:
Secure Connection Failed
An error occurred during a connection to prepaid.cape-connect.com.
Cannot communicate securely with peer: no common encryption algorithm(s).
(Error code: ssl_error_no_cypher_overlap)
Any ideas how to fix this?
Do you have the latest version on your x86 box?
I’m running RouterOS 4.3 and I’m running the stable version of User Manager that came with RouterOS 4.3
Do you have this problem in all browsers?
IE, FF and Chrome are what I used to test. It’s the same in all of them.
