I’ve got some major problems by SSL securing the hotspot pages.
First the Situation:
I have an GlobalSign SAN certificate to cover two domainnames. It regards hotspot.domain.com and portal.domain.com.
(https) hotspot.domain.com is an A records which points to 10.5.50.1 the local hotspot address.
(https) portal.domain.com is an public available webpage.
As you already expected hotspot.domain.com redirects to portal.domain.com which does the authorisation check and redirects with the login back to hotspot.domain.com, checks result and redirects it data back to portal.domain.com.
Now portal.domain.com is working fine when i’m on a direct internetconnection, but when i’m connected to the hotspot i will get an ssl verfication error on hotspot.domain.com and portal.domain.com. For now i discoverred the usuage of the url http://crl.globalsign.net/*.crl so I walledgarden-ip it. but for now the problem stays.
Did someone got this work?
Best Regards,
Johan
