SSTP and Windows 7 as a client
Hello.
I have created 2 files through Mikrotik (private-key.pem and certificate-request.pem). Then created an instant ssl cert by COMODO (90 days free) with this cert request. After that imported the cert from Comodo into Mikrotik and also imported the private-key.pem. Everything looks ok, the certificate → print shows:
Flags: K - decrypted-private-key, Q - private-key, R - rsa, D - dsa
0 KR name=“cert2”
subject=OU=Domain Control Validated,OU=Free SSL,CN=sstp.merit.ee
issuer=C=GB,ST=Greater Manchester,L=Salford,O=COMODO CA Limited,
CN=EssentialSSL CA
serial-number=“3C4CC847173FB353CA2D8B9BDD1512B8”
invalid-before=mar/21/2012 00:00:00 invalid-after=jun/19/2012 23:59:59
ca=yes
I received a certificate from Comodo to import into win 7 Trusted Root CA. This is also done.
Now when I connect win 7 using SSTP to the CN then I get this error:
Error 631: The user disconnected the modem (or other connectin device).
Need help, the sstp is a must in my network. I need to get it working.
Ahto Metting
ESTONIA
Upgrade to 5.14 and it will work … assuming that you are not running x86 version on older Intel Pentiums where SSTP on 5.13/5.14 fails alltogether.
GL
Thank for the tip. I had this on my mind for some time (upgrading to a newer version). Mostly I quickly upgrade to newer version but for this testing Mikrotik RB450G, I somehow did not feel like I should do that.
I will write about the result.
Thanx a lot. I got it working.
is there a working tutorial how to setup a Mikrotik SSTP server and Windows7 Client with SSL certificate?
I try to make it working with no success!
Thanks!
