Is SSTP recommended or otherwise, for a site to site VPN over l2tp/ipsec? Both ends will be mikrotik 5.0rc3.
Itd probably be stable for 1 connection. With the ~140 connections I run, its not stable.
If its just 2 sites, IPSEC, or even ipip in ipsec is better.
What was the issue you were having? Seems with just one connection, traffic randomly stops and connection dies and re-establishes.
Im trying to create a hub-and-spoke type VPN, were the remote networks connect to a hub, and at the hub all NAT and QoS happens.
Issue I AM having is a memory leak, SSTP server dying randomly, connections seem pretty stable when everything else is working, though. 1/2 the connections will stay up for days on end, the other 1/2 will drop off anywhere between 1 and 12 hours. Most likely ISP issue on their end.
I am running hub/spoke.
I switched to IPIP with IPsec and its working awesome. So it stays.
Thanks!
