Hey forumites, hoping I can get some assistance on this issue here. Might be a bug in ROS.
Currently having a SSTP issue with MikroTik (v6.43.2: CCR1009-8G-1S-1S+) whereby authentication to ppp only works some of the time. If I retry a few times after waiting a bit, it connects successfully.
MikroTik config:
/ppp secret
add local-address=192.168.201.99 name=ddremote password=supersecure remote-address=192.168.201.100
/interface sstp-server server
set certificate= enabled=yes
MacOS CLI:
sudo /usr/local/sbin/sstpc --log-level 5 --log-stderr --cert-warn --user “ddremote” --password “supersecure” 192.168.2.253 require-mschap noauth noccp noaccomp noipdefault nomagic novj user “ddremote” password "supersecure"Worth noting that my sstpc works perfectly (every time) with a Windows-controlled DC and different connection variables.
MikroTik log:
22:33:08 sstp,ppp,debug : LCP lowerup
22:33:08 sstp,ppp,debug : LCP open
22:33:08 sstp,ppp,debug,packet : sent LCP ConfReq id=0x1
22:33:08 sstp,ppp,debug,packet <magic 0x398c4ed2>
22:33:08 sstp,ppp,debug,packet : rcvd LCP ConfReq id=0x1
22:33:08 sstp,ppp,debug,packet : sent LCP ConfRej id=0x1
22:33:08 sstp,ppp,debug,packet : rcvd LCP ConfRej id=0x1
22:33:08 sstp,ppp,debug,packet : sent LCP ConfReq id=0x2
22:33:08 sstp,ppp,debug,packet : rcvd LCP ConfReq id=0x2
22:33:08 sstp,ppp,debug,packet : sent LCP ConfRej id=0x2
22:33:08 sstp,ppp,debug,packet : rcvd LCP ConfRej id=0x2
22:33:08 sstp,ppp,debug,packet : sent LCP ConfReq id=0x3
22:33:08 sstp,ppp,debug,packet : rcvd LCP ConfReq id=0x3
22:33:08 sstp,ppp,debug,packet : sent LCP ConfNak id=0x3
22:33:08 sstp,ppp,debug,packet <magic 0x1fed7cc6>
22:33:08 sstp,ppp,debug,packet <asyncmap 0x0>
22:33:08 sstp,ppp,debug,packet : sent LCP ConfAck id=0x2
22:33:09 sstp,ppp,debug : LCP timer
22:33:09 sstp,ppp,debug,packet : sent LCP ConfReq id=0x4
22:33:09 sstp,ppp,debug,packet <magic 0x398c4ed2>
22:33:09 sstp,ppp,debug,packet : rcvd LCP ConfRej id=0x4
22:33:09 sstp,ppp,debug,packet : sent LCP ConfReq id=0x5
22:33:09 sstp,ppp,debug,packet : rcvd LCP ConfAck id=0x5
22:33:09 sstp,ppp,debug : LCP opened
22:33:09 sstp,ppp,debug : LCP close
22:33:09 sstp,ppp,debug : LCP closed
22:33:09 sstp,ppp,debug,packet : sent LCP TermReq id=0x6
22:33:09 sstp,ppp,debug,packet peer refused to authenticate
22:33:09 sstp,ppp,debug : PPP received non-LCP packet (0x8021) when LCP not open
22:33:09 sstp,ppp,debug : PPP received non-LCP packet (0x8235) when LCP not open
22:33:09 sstp,ppp,debug,packet : rcvd LCP TermAck id=0x6
22:33:09 sstp,ppp,debug : LCP lowerdown
22:33:09 sstp,ppp,debug : CCP close
22:33:09 sstp,ppp,debug : BCP close
22:33:09 sstp,ppp,debug : IPCP close
22:33:09 sstp,ppp,debug : IPV6CP close
22:33:09 sstp,ppp,debug : MPLSCP close
22:33:09 sstp,ppp,debug : LCP down event in initial state
MacOS log:
Oct 10 22:33:09 sstpc[27420]: Resolved 192.168.2.253 to 192.168.2.253
Oct 10 22:33:09 sstpc[27420]: Connected to 192.168.2.253
Oct 10 22:33:10 sstpc[27420]: The certificate did not match the host: 192.168.2.253
Oct 10 22:33:10 sstpc[27420]: Server certificated failed verification, ignoring
Oct 10 22:33:10 sstpc[27420]: Sending Connect-Request Message
Oct 10 22:33:10 sstpc[27420]: SEND SSTP CRTL PKT(14)
Oct 10 22:33:10 sstpc[27420]: TYPE(1): CONNECT REQUEST, ATTR(1):
Oct 10 22:33:10 sstpc[27420]: ENCAP PROTO(1): 6
Oct 10 22:33:10 sstpc[27420]: RECV SSTP CRTL PKT(48)
Oct 10 22:33:10 sstpc[27420]: TYPE(2): CONNECT ACK, ATTR(1):
Oct 10 22:33:10 sstpc[27420]: CRYPTO BIND REQ(4): 40
Oct 10 22:33:10 sstpc[27420]: Started PPP Link Negotiation
Oct 10 22:33:10 sstpc[27420]: RECV SSTP DATA PKT(23)
Oct 10 22:33:10 sstpc[27420]: PPP LCP ID: 1 CONFREQ AUTH: CHAP MAGIC: 0xD24E8C39
Oct 10 22:33:10 sstpc[27420]: SEND SSTP DATA PKT(23)
Oct 10 22:33:10 sstpc[27420]: RECV SSTP DATA PKT(17)
Oct 10 22:33:10 sstpc[27420]: PPP LCP ID: 1 CONFREJ AUTH: CHAP
Oct 10 22:33:10 sstpc[27420]: SEND SSTP DATA PKT(17)
Oct 10 22:33:10 sstpc[27420]: RECV SSTP DATA PKT(22)
Oct 10 22:33:10 sstpc[27420]: PPP LCP ID: 2 CONFREQ MAGIC: 0xD24E8C39 AUTH: PAP
Oct 10 22:33:10 sstpc[27420]: SEND SSTP DATA PKT(22)
Oct 10 22:33:10 sstpc[27420]: RECV SSTP DATA PKT(16)
Oct 10 22:33:10 sstpc[27420]: PPP LCP ID: 2 CONFREJ AUTH: PAP
Oct 10 22:33:10 sstpc[27420]: SEND SSTP DATA PKT(16)
Oct 10 22:33:10 sstpc[27420]: RECV SSTP DATA PKT(18)
Oct 10 22:33:10 sstpc[27420]: PPP LCP ID: 3 CONFREQ MAGIC: 0xD24E8C39
Oct 10 22:33:10 sstpc[27420]: SEND SSTP DATA PKT(18)
Oct 10 22:33:10 sstpc[27420]: PPP LCP ID: 3 CONFNAK MAGIC: 0xC67CED1F
Oct 10 22:33:10 sstpc[27420]: SEND SSTP DATA PKT(20)
Oct 10 22:33:10 sstpc[27420]: PPP LCP ID: 1 CONFREQ ASYNCMAP: 00 00 00 00
Oct 10 22:33:10 sstpc[27420]: RECV SSTP DATA PKT(20)
Oct 10 22:33:10 sstpc[27420]: PPP LCP ID: 1 CONFREJ ASYNCMAP: 00 00 00 00
Oct 10 22:33:10 sstpc[27420]: SEND SSTP DATA PKT(12)
Oct 10 22:33:10 sstpc[27420]: RECV SSTP DATA PKT(12)
Oct 10 22:33:10 sstpc[27420]: PPP LCP ID: 2 CONFACK
Oct 10 22:33:11 sstpc[27420]: RECV SSTP DATA PKT(18)
Oct 10 22:33:11 sstpc[27420]: PPP LCP ID: 4 CONFREQ MAGIC: 0xD24E8C39
Oct 10 22:33:11 sstpc[27420]: SEND SSTP DATA PKT(18)
Oct 10 22:33:11 sstpc[27420]: PPP LCP ID: 4 CONFREJ MAGIC: 0xD24E8C39
Oct 10 22:33:11 sstpc[27420]: RECV SSTP DATA PKT(12)
Oct 10 22:33:11 sstpc[27420]: PPP LCP ID: 5 CONFREQ
Oct 10 22:33:11 sstpc[27420]: SEND SSTP DATA PKT(12)
Oct 10 22:33:11 sstpc[27420]: PPP LCP ID: 5 CONFACK
Oct 10 22:33:11 sstpc[27420]: PPP IPCP ID: 1 CONFREQ ADDR: 0.0.0.0
Oct 10 22:33:11 sstpc[27420]: SEND SSTP DATA PKT(24)
Oct 10 22:33:11 sstpc[27420]: PPP ACSP ID: 1
Oct 10 22:33:11 sstpc[27420]: RECV SSTP DATA PKT(40)
Oct 10 22:33:11 sstpc[27420]: PPP LCP ID: 6 TERMREQ
Oct 10 22:33:11 sstpc[27420]: PPP LCP ID: 6 TERMACK
Oct 10 22:33:11 sstpc[27420]: Unrecoverable SSL error
Oct 10 22:33:11 sstpc[27420]: Connection was aborted, Reason was not known
**Error: Connection was aborted, Reason was not known, (-1)
