I have been running into this problem repeatedly lately.
Client – RB951G-2HnD
RouterOS 6.18
Firmware 3.18
Server – CCR1009-8G-1S-1S+
RouterOS 6.18
Firmware 3.10 and 3.18
Client establishes SSTP connection, and server assigns IP address as defined in the username/password (Secret Section).
Sometimes this works fine, other times, the client red-flags the given IP address as DI (Dynamic Invalid).
Deleting the addresses does no good. Disabling the client profile does no good. Rebooting does no good, etc…
The only thing that SOMETIMES works is downgrading the RouterOS to 6.7 and then re-Upgrading to 6.18.
I say SOMETIMES because I have a couple boards that would revert to the problem behavior immediately after re-upgrading to 6.18. I had to keep them on 6.7 for the system to work at all.
Has anyone else experienced this, and have you found a usable solution and/or root-cause?
Unfortunately that link didn’t really help. I don’t have the option of swapping around who is the hub and who is the spoke whenever the problem rears it’s head. This has now happened to 6 or 8 of my production units. I’ve tried 6.18 through 6.22 hoping that a newer version has fixed the problem. But it still remains even with 6.22.
To make matters worse, now Mikrotik is sending out units that come from the factory with 6.20 and refuse to downgrade to 6.7 without losing the RouterOS license!!
If anyone has found a fix for this, or a way to reset the DI issue without a RouterOS downgrade, please chime in!!!
