SSTP Client Problem
Hi guys
i have a problem with SSTP Client on Mikrotik Router OS 7.6
When I create a connection SSTP Client in version 7.6, there is a problem and not connecting
But this problem does not exist in version 6.49
In version 7.6, it shows a connection error “Closed by Peer Remote”
please help
https://forum.mikrotik.com/viewtopic.php?p=908118
@persianmsr
Try downgrading to 7.5. I have same situation. Works perfectly any v6.x and won’t work 7.6 and 7.7b10. I downgraded to 7.5 and it works.
I have a ticket open with mikrotik. Let me know if that works for you. Turning on debug logging was useless. Its disconnecting the server end with the same error you are getting.
Hi
Did you get reply from support. I have the same issue 7.5 works as expected.
This in the 7.6 change log
" sstp - added VRF support for client "
Regards
I’ve issues too. I’ve a bounch of about 20 sstp clients connects to a 7.11.2 CHR sstp server.
In a few seconds the CHR does not ping constantly.
Same config on a 6.49.8 works.
