SSTP connection limits
Hi dear, someone have more than 200 sstp tunnel connected using ruoterboard as server?
What is the problem you are facing?
Yes, purchase higher level of license, L4 = 200, L5 = 500, L6 = unlimited, (Keep in mind which routerboard you have and resources available on it)
https://wiki.mikrotik.com/wiki/Manual:License
My routerboard is ccr1036 with l6… Never see more than 201 connection
well 201 is more than 200, lol, just joking.
I really do not know, never had requirement for so many VPN connections, maybe reached hardware limits?
If you see 201, what happens if you try and connect via SSTP?
On the client unable to connect or sometime for few second it reach 201 and after some second some other old established vpn go down…
My suggestion will be to log a call with support by sending a mail to support@mikrotik.com.
Will be interesting to know what their response will be
