Hello All
PPP Server : SSTP
enabled: yes
port: 443
max-mtu: 1500
max-mru: 1500
mrru: disabled
keepalive-timeout: 60
default-profile: SSTPvpnProfile
authentication: pap,chap,mschap1,mschap2
certificate:
verify-client-certificate: no
force-aes: no
pfs: no
tls-version: any
**Certificate Status : KLT
Authentication : Radius
PPP Profile:
/protocol tab> use Encreption = required**
Problem :
Clients Side Error message:
Plathform: windows 10 with SSTP connection.
error message :
" The remote connection was denied because the username and password combination you provide is not recognized, or the selected authentication protocol is not permited on the remote access server "
I can connect with the same username/password via L2TP IPsec.
Server side:
user < username> authentication failed.
Kindly reply me if you have any Idea.
Thank You
Best Regards
AliYashar
