sstp idle time
The displayed idle time doesn’t make sense, and may be why sstp is so unreliable, with constant timeouts where each end reports the other has disconnected.
idle-time (time) Elapsed time since last activity on the tunnel.
On a very busy sstp connection you get an idle time = uptime, the opposite to what it should be.
status: connected
uptime: 37m3s
idle-time: 37m3s
mtu: 1500
local-address: 172.20.201.18
remote-address: 172.20.201.17
rx-packets-per-second: 226
rx-drops-per-second: 0
rx-errors-per-second: 0
rx-bits-per-second: 75.1kbps
tx-packets-per-second: 242
tx-drops-per-second: 0
tx-errors-per-second: 0
tx-bits-per-second: 2.7Mbps
Is this a bug ?
Nope, it’s gone in 6.3
