sstp radius windows smart card
I have set up the radius authentication for my sstp connections.
cala is working properly.
On the other hand, if I try with a smart card, it does not work.
mistake:
it was not possible to establish a connection to the remote computer (router I suppose) so the port used for this connection was closed.
is this a bad configuration on my part or is this mikrotik
thank you
