is it possible to configure / change priority of SSTP server encryptions? So we can enforce AES128 encoding over AES256.
Also does someone have advice on SSTP connection stability, since it seems to break every hour or so…
Thanks in forward!
Thanks in forward!
I wouldn’t know how to enforce AES128 encoding over AES256 but I can assure you that SSTP connections are quite stable.
I had SSTP uptimes of over 30days before I upgraded my router to ver6.41 some five days ago.
And now? ![]()
Is it Mikrotik - Mikrotik SSTP or you are connecting from Windows client?
I have noticed weird behaviour: seems SSTP resets after “Idle-Timeout” counter no matter if connection is active or not… Now I have increased / removed this timeout and it is “stable”.
