I'm trying to setup hAP ac as SSTP server for Windows client following Mikrotik wiki but not succeeded yet..
When I trigger to connect from Windows 10 PC, it said "Connection closed"(not sure exact English error message because of translation and when I tried to check with browser by https://xxxxx, I got connection reset. Log said nothing. Certificate (wild card) is installed. I also tested PPTP and L2TP and those worked good.
Do you have any advice where I should look into?
Any comments are much appreciated.
Here's my config, hiding sensitive.
jan/18/2020 17:34:54 by RouterOS 6.46.2
software id = 7PHY-88UU
model = RouterBOARD 962UiGS-5HacT2HnT
serial number = 702406F25A73
add admin-mac=6C:3B:6B:13:7E:CD auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=japan disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-137ED3 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=japan disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-137ED2 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.200
add name=pptp ranges=192.168.88.201-192.168.88.240
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add local-address=pptp name=pptp remote-address=pptp
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
/interface l2tp-server server
set authentication=mschap2 default-profile=pptp use-ipsec=required
/interface pptp-server server
/interface sstp-server server
set authentication=mschap2 certificate=STAR_domainname_co_jp.pfx_0 default-profile=pptp enabled=yes force-aes=yes pfs=yes
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input dst-port=22 protocol=tcp
add action=accept chain=input dst-port=80 protocol=tcp
add action=accept chain=input dst-port=443 protocol=tcp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip service
set www-ssl certificate=STAR_domainname_co_jp.pfx_0
/ppp secret
add name=schino profile=pptp
/system clock
set time-zone-name=Asia/Tokyo
/system logging
add topics=sstp
add topics=ppp
add topics=certificate
add topics=ssh
/system ntp client
set enabled=yes primary-ntp=10.20.20.1
/tool mac-server
/tool mac-server mac-winbox
Here's log when connection failed. I enabled SSTP facility.
17:37:53 sstp,ppp,debug : CCP close
17:37:53 sstp,ppp,debug : BCP close
17:37:53 sstp,ppp,debug : IPCP close
17:37:53 sstp,ppp,debug : IPV6CP close
17:37:53 sstp,ppp,debug : MPLSCP close
17:37:53 sstp,ppp,debug : LCP lowerdown
17:37:53 sstp,ppp,debug : LCP down event in initial state
