Setup the VPN works good site 1 and 2 are connected LAN to LAN
Now the question is how to force one computer in site 1 to appear as if it connected in site 2 and take the public IP of site 2?
The rest of the traffic in site 1 will go to internet as usual outside of the tunnel.
Thanks,
Does it mean the computer should be present in local bridge of remote network? If yes, run eoip tunnel and bridge the local computer port wit the remote network over it.
Thanks for the help,
Now I believe that the SSTP is still needed, Is that correct?
Does anybody have an example?
Thanks in advance,
Sstp is good when you want to route between the networks. But you need to bridge thru so you need eoip. Eoip can run both inside the sstp and outside the sstp. Outside will be faster but not secured. Try both and seeā¦
