SSTP VPN Backdoor not routing
I am trying to setup a backdoor into my network. I have a sstp server setup on my cable connection (192.x.x.x). When I connect I am assigning a 10.x.x.x that matches the corperate network. It wont ping unless I have proxy-arp on or i have also setup a nat rule on the internal interface to make it work. My default gateway is setup to the 192.x.x.x/24 and I have a static route for anyting 10.x.x.x/24 to route out that network gateway. Right now it doesnt seem the static route is working correctly. Wondering if I should be assigining another subnet to the VPN and routing all traffic from it. Any advice would be great. Thanks
