I’m trying to setup a an SSTP VPN server for Windows 7/8 clients to use and seem to be getting nowhere. I have installed a publicly trusted certificate and enabled the SSTP server from PPP. For the purposes of testing I have disabled all firewall rules. Whenever I try and connect from a Windows 7 or 8 client I simply get error 619 “the report port was closed because a connection to the remote computer could not be established.” I have confirmed that the same VPN user can login via PPTP so clearly I can communicate with the server. Any advice on how to troubleshoot would be greatly appreciated (running /log print displays absolutely nothing about the failed SSTP connection).
Here’s the output of /interface sstp-server server
enabled: yes
port: 1234
max-mtu: 1500
max-mru: 1500
mrru: disabled
keepalive-timeout: 60
default-profile: test_AD
authentication: chap,mschap1,mschap2
certificate: cert1
verify-client-certificate: no
force-aes: no
