SSTP VPN Hub and spoke
Hi All,
Before release 7 (using 6.49) I successfully deployed an SSTP based hub and spoke infrastructure testing OSPF / RIP routing over the SSTP tunnels. HUB with static public IP and SPOKEs with dynamic IP using HW devices.
Now for some reasons I’m testing the same setup with an HW based HUB with rel 7 and 6.49 CHR SPOKEs.
The SSTP tunnels are correctly UP but there is no way to establish OSPF or RIP neighborships between the HUB and the SPOKE routers.
Can you help troubleshooting this issue ?
Is there any need for using protocols like SSTP and RIP?
Did you get proper connectivity when using the point to point addresses?
Did you explicitly configure the peers in OSPF? Remember SSTP does not support multi/broadcast.
