Stability of HWMP+ using Mesh Interface
Hello All!
Sceanrio: We are making a decentralized network, where each mikrotik module communicate to each other mikrotik module. At the same time mikrotik modules are in motion which means the topology is changing.
Solution: We used HWMP+ protocol to make the network. The modules are configured with dynamic wds on mesh interface.
Problem: The HWMP+ protocol is not very stable. The WDS links suddenly disappears. The instablility increases as the modlues start moving.
Any suggestion, what would be a good solution for such a scenario, where the network changes its topolgy all the time. Should RSTP be a good solution.
