stable mikrotik ? :(
telnet://159.148.147.225:23/
mikrotik v2.8.16
Login: demo
Password:
could not connect to console, try rebooting the router
I’m surprised …
I’m surprised too. Can you upgrade it to 2.8.17 (18) ? If you can connect with keyboard and monitor, do the command system check-install and see if there are any errors displayed. If not, make a supout.rif file and send it to us.
Ooops… What are the rights the “demo” user has in user management? (/user print)
that host is: http://demo.mt.lv :wink:
OMG :smiley: stupid me .. :smiley:
it’s back online
What was the problem?
'Cause I have a 2.7.20 system with the same problem: no telnet, no console, just winbox. And no log :frowning:
reboot + upgrade. problem gone
not upgradable, moe than a year old, and its a wired router, so not for why to upgrade. Reboot did not help. I can use it as a router, but still it would be better to log on localy too in any case.
for 2.7 i can’t tell you if there were any issues, i don’t remember anything like it. maybe unstabile hardware? did you try power cycle (power off, power on)? remove any unused packages from it, then reboot normally (sys reboot).
I will try remove unneeded packages, and do the reboot. I can do it only after midnight, because a huge traffic goes througt it now.
Thanks for help, I will report tomorow.
I had the same problem, after a few days, the only solution was CTRL+ALT+DEL
I upgraded my test router to 2.8.17 after I discovered this problem.
now winbox dosen’t work anymore
first click & goodbye
you mean on the demo router? checked. works for me
for me don’t
winbox downloaded from demo.mt.lv
Win XP SP2
after clicking interfaces i’ve get worng username
same setup here. XP Sp2, Winbox downloaded from demo.mt.lv and No problems. Try another computer and see what happens there
.18?
Where can this version be downloaded?
I wanted to ask the same :wink: When it will be released?
Hopefully not before the package is 100% stable.
I meant upgrade to 2.8.17 or .18 when it is released. We have it on the demo router, and it is being tested on other routers as well. We will release it when it’s ready
