Stable package on X86
Hi
Mikrotik team please we need stable version with x86 because all packages starting from 5.7 is not stable with X86 ,
with thanks
5.12 is not working for you? what is the problem?
+1 for that…
overall non-stability , sometimes the server hang up until we reboot it .
PPP users can not logging on with heavy use while with 5.7 they are easily access with same load .
thanks
5.8 is stable since weeks on my x86
br
+1 for that.
ROS 5.10 - 5.12 very unstable in ppp, we had 3 hungs than we downgrade to 5.6
5.8 is ok , but i see 5.7 is quit stable better than others specially with X86 ,
Mikrotik team , please we need stable version on X86 .. hope to see that in 5.13
thanks
in my case, x86, 500+ Mbits links, 10 lan interfaces, 8 cores i7 and so on…
the best stable version is 5.0rc7.
When in newer version after the crash I am asked from helpdesk for support file, I believe they are jocking :laughing:
How can I make a support file just before crash/freeze/hangup ?!?
Please, Mikrotik, please tell me that !
not ‘just before’, but ‘just after’
