stable release for BGP
What version of RouterOS that stable and works well bgp / vrf / mpls.
I have been testing these features in version 6:21 and I have not had much success.
Are default routes that mikrotik is spreading without my having explained it.
VRF are having the correct routes that were configured, but not dripping.
Ie several bugs.
Does anyone have any suggestions?
Hard to comment on your claims … Could it be what you are experiencing is due to some missing configuration ?
You can post a config, and use that to start a discussion…
:slight_smile:
Everything is bridged via local bridge, but on router 10.0.0.1 I created separated bridge called “switch” and assigned eth4 port to it,
I also created two VPLS interfaces with different VPLS ID and assigned them to bridge “switch” on this router.
