hi all,
i’ve purchased 2 units of 1100ahx2 and i cant figure out how to stack the routers to make it used as if a 20port router.
anyone?
hi all,
anyone?
Never heared about stacking with mikrotik.
But you might be able to achieve your goals with manual configuration. But depends on what you want. You can do failover with VRRP and use scripts to synchronize firewall configuration. But you have to build synchronization “by hand”.
I am also trying to accomplish this, but for different reasons. Does anyone know how to do it?
It doesn’t make logical sense to “stack” a mikrotik running routerOS, you should see if switchOS has this feature as its a true switch OS. I haven’t been able to find anything either…
