I know you can’t bridge wireless station and ether1, but does it some how magicly work if you are using ntreme? ![]()
‘mode=station-wds’ should be used for wireless interface, when you have Nstreme .
WDS cann’t be used in Dual Nstreme links.
Optionally…
I thought Nstreme did not work with WDS. Is AP-Bridge with WDS what does not work with WDS?
“Nstreme AP-Bridge WDS” to “Nstreme AP-Bridge (or WDS-slave) WDS” does not work, but “Nstreme AP-Bridge WDS” to “Nstreme Station-WDS WDS” works fine.
It makes sense, in a polling AP to polling AP situation, who would control the polling?
–Eric
I have it setup with the AP-Bridge with WDS enabled and the wds-station is working fine. Both have Nstreme turned on.
