Stale routes and Web Access
Getting a build up of unknown routes for old pppoe sessions from clients on MT RouterOS 2.8.8. Is this common, and will it cause any adverse affects?
Also, to add to that, since upgrading to 2.8.8 users are suffering from the effects of incorrect TCP MSS window sizes, even tho each connection is automatically being mangled - it is as if the mangling isn’t taking affect… I have since turned off the automatic mangle rule and when back to manually adding them. I’ll keep and eye on it and see if it helps.
I think the last PPPoE changes were done in v2.8.9 – so I would suggest upgrading to v2.8.11 and if you see any problem, send the supout file to support@mikrotik.com . There are no reports of any problems with v2.8.9 10 or 11 that we are working on.
John
