Anybody know what the Break Key Combination is for accessing a cisco device attached to serial port accessed from /system serial-terminal
Regards
Regards
[Q - quit connection] [A - send Ctrl-A prefix] [R - autoconfigure rate]
So from my understanding i must press CTRL-A and then B to product break, however this doesn’t seem too work…
Input?
Well this one is solved.
Select Port
Push CTRL-A and R to auto detect port settings.
Then CTRL-A and B to produce break.
Regards
