Starting Dude on Linux upon boot
Has anyone come up with a solution to start the Dude server so all you have to do is reboot the server? I would like to put my Dude server (that is running CentOS and Gnome) in a rack and not have to get some sort of head to it just to start Dude.
I tried using an init script and /etc/rc.local but when invoked by root from the init stage $DISPLAY is empty so wine doesn’t know where to put the window for Dude.
If the command is executed from the GUI terminal it works perfectly fine, but I don’t know how to automate anything like that. Has anyone figured this one out?
Hi
Little faq:
edit /etc/inittab:
Default runlevel. (Do not set to 0 or 6)
edit /etc/X11/xdm/Xsetup_0:
run dude
/usr/bin/wine /root/.wine/drive_c/Program\ Files/Dude/dude.exe --server &
Work fine :wink:
Torin
I found a solution already. The above post won’t work, I don’t believe.
Dude requires to run from wine. Wine requires X. While root is going though init.d it has no X interface to output what is necessary for Dude =/
And what is the solution you have found and does it work … ?
Half way at this point.
It will automatically login with my custom user, and will start The Dude. However, it is unable to ping anything (local problem). I used the GUI in the System menu on CentOS 5.
The user itself can ping from the shell (probably a GUI app, if there is one) so I know it isn’t a permissions issue. I haven’t had any time to work on this, but I will post when I get it figured out.
Solved by using RouterOS instead of a Linux distro.
thx, solved by running under administrator previledged :slight_smile:
The best way is using xvfb-run
I run it in an nx session. Installed nomachine on my server which is a secure remote access management software. Log into it and run the dude on that session, then disconnect from the session and it stays running.
I have centOS and I installed RouterOS on XEN. Then installed the dude on routeros. and it works fine.
The Dude on wine is not stable and it’s requiring X server.
